Ok so I am moving the fuel filter housing to make rom in the engine bay (just in case ).
I am going to put it on the frame rail next to lift pump. Should I put the lift pump so it puts pressure thru the filter )like stock) or set it up so the filter is before the lift pump and the lift pump pulls fuel thru the filter.
also will it be a good Idea that far away from the cp3 as I will have a bypass around the lift pump and when the lift pump is un needed, I t will be off...?
