Moving the ECM!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
I want to move my ecm from its stock position to the spot where my drivers side battery is. My question is dose the ECM need to insulated from all mounting pionts like it is in the factory holder or can it be in contact with ground (-)?
Thanx
Caleb
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Pat hasn't had any problems with it. Right now the TCM is mounted on top of the battery on Casper.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Thanx Kat, I put some rubber peices under the ecm and used three of the 4 screw holes and screwed it dowm to the battery tray. I also mounted the controler for the flex lite fans there as well.
Thanx,Again , i just want to ask befor i screwed up to bad!!! I'll post some pics as soon im finished up here!!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Heres some pics!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
ECM needs to be insulated. If its grounded you can run into issues with it not wanting to start.
AHH ok i better do that then! I have a plan but i just need some parts and the dang hardware store closes @ 8. Dang livin out in the middle of nowhere!!!!
Thanx John!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Mostly i needed a clean looking place to put the fan control, so lost the weight of a battery and found a good place to put them, then i just decided to move the ecm because it looked rather easy to do at this point, plus it will give me some more room to make som bigger intercooler piping when ever i become less lazy and actually make some!!!
9,903
149
Looks good!
And yes insulate it well for two reasons, I have heard the grounding issue can cause starting problems - something about static electricity IIRC. And also to keep vibration to a minimum.
mde
fuel injection is my life
Mar 17, 2007
396
Bucky State
The insulation is a damper for vibration, the ECU is inside grounded with the battary and vehicle. You need the ECU grounded in some way but it's already made inernaly, so don't worry.
V
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Cool stuff! Custom is always neat :D
Looks good!
Thanx guys!!
V
Thanx, I now have it insulated from all my mounting points with rubber washers top and bottom and i put heat shrink on the screws where they go through the ecm so the sides of the screws wont touch!
Later
Caleb
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Caleb
I decided to relocate mine also:),But still need to fab a mount and I hope it wont get to hot
It just seem to fit so good inbetween there
9,903
149
God I can't wait to get that engine back in and get that thing running so we can finally start tiding up the wiring!!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Oh my, Talk about putting the Squeeze on things!!!!
I just had to put mine back into the stock location due to running out of room on the other fender!!!
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
I moved mine that same location mounting it up off the a custom tray with 1/2" rubber washers, then mounted the other on top of it using hi dens foam. You can lose the bracket under the (almost 2.0 lbs) battery tray mounted to the core support as well...
The wires looked exposed so i picked up some 1" and 1.5" shrink and shrunk it all down over the wires, thought when i changed the angle they would be suceptible water spray. They make the shrink in pretty colors to...
The bitch was tieing the batteries back into the fuse box from the back... to the stock location! big cable no likey bendie.
Looks sweet man, congrats!!
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
i'd like to do mine too but im going to get some rubber isolator type mounts to mount it with, much better than the washers IMO. think MSD has some but im gonna use some nice soft BMW ones like i mounted my lift pump with! Looks good guys!
