As the title states, Im contemplating moving the springs inboard the frame on the 1/2 ton so-as to gain room for larger rear tires. I am looking for advice/opinion from guys who know suspensions far better than I (cough cough James cough cough) on what pitfalls I may run into by doing this.
Keep in mind that I am only using 2 leaves of the springs and they will essentially be locators for the rear axle, as I am going to run adjustable coilovers for suspension.
The way things are measuring out, the springs will end up above that flat platform next to the existing spring perches on the 9.5" 14 bolt, so they'll be about 6" inboard from where they are now. This will neccesitate removing the existing shock mounts and moving them inboard between the springs and diff, but that was something I was planning anyway. I plan on using some sort of rear stabilizer bar to help regain some of the lost handling, while either running my Caltracs (as from what Ive read it seems they would still work in this configuration) or a ladder bar of some kind.
I just wonder if it make the truck unstable as far as drag racing? In my reading, I find that this is a common change made by Mopar and Chevy owners to gain wheel well width for their cars, but we're talking a 4500lbs truck, not a 3000lb car.
I appreciate any insight.
