INSTRUCTIONS FOR REPLACING MOUSE BALLS
Mouse balls are now available as FRU (Field Replacement Unit).
Therefore, if a mouse fails to operate or should it perform erratically,
it may need a ball replacement. Because of the delicate nature of this
procedure, replacement of mouse balls should only be attempted by
properly trained personnel.
Before proceeding, determine the type of mouse balls by examining the
underside of the mouse. Domestic balls will be larger and harder than
foreign balls.
Ball removal procedures differ depending upon the manufacturer of the
mouse. Foreign balls can be replaced using the pop-off method. Domestic
balls are replaced by using the twist-off method.
Mouse balls are not usually static-sensitive. However, excessive handling
can result in sudden discharge.
Upon completion of ball replacement, the mouse may be used immediately.
It is recommended each replacer have a pair of spare balls for maintaining
optimum customer satisfaction. Any customer missing his balls should
contact the local personnel in charge of removing and replacing these
necessary items.
foreign balls.
necessary items.
