more hp
lly dmax
Jan 2, 2011
14
im putting new head gaskets in right now and i am wondering if ther is any free or close to free things i can do while the motor is tore down. or even after i get it back together.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
It all depends on setup. Porting and polishing them will take some time but should see lower egts increases ariflow etc.
Just curious why you say this:confused: he asked for free mods
Well because if he is asking about porting he is obviously not going to do it him self ( I'll assume) so now he is going to pay a shop to do it?not free
And for what? I bet he wouldn't even notice any difference with a stock turbo:(
Jmho
9,906
152
Not sure what your plans are for the truck but one thing I would do while you have it apart, although not free, is put a set of head studs in. In case you end up with twins down the road. You gotta buy or should buy new head bolts anyhow.
lly dmax
Jan 2, 2011
14
well i dont have many plans for it. i have an edge juice but no attitude so its only 90 horse, but i want to put a intake system and maybe a small fuel system on it. but i was just wondering about any cheap or free things i can do to help out if there really is any.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Remove the EGR completely. You can have your up-pipe welded shut fairly cheap or do it your self if you can weld stainless. Make a plate to bolt onto the the back of the egr motor to seal it up. Re-route your PCV to the atmosphere. And since you will have all that gone you can clean up everything in the intake tract that got all gummed from it. I would also pull your intercooler out and clean all the oily residue out of it, and the boost tubes.
This may not gain you any HP, but it certainly wont hurt, and its just a good idea to do while your in there.
Don't mod your regulator unless you willing to pay for custom tuning, buy efi live, or put up with a possible "lopey" idle.
