Modified Single CP3?
mick
Try anything
Aug 15, 2006
482
Forestdale. Brisbane.Australia
I need to remove my PPE Dual CP3 to make room for another Supercharger. What is the best option for a Performance Single CP3 in the stock position? Who makes a modified one and what hp levels are they capable of? Any help appreciated.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Industrial Injection makes one or else check the part # of your PPE and see if it is a lbz/LMM those are a little better than LLY/Lb7 and then use it as your main
them purchase or make a modded regulator
SmokeShow
6,818
Lawrenceburg, KY
the company Larry mentioned in TX is Darkside Diesel. I hear that their pumps are really good and have enough fuel flow to power 700+ trucks.
I have no personal experience with any modified pumps yet but will here before long. My top two choices after searching are FloorIt Diesel's stage II or III pump or the Darkside Diesel pump. Third would be II. It is quite hard to get in touch with John at FloorIt though as he evidently busy beyond belief. He does return calls and messages it just takes him a long time. So that is frustrating but his pumps are proven to be able to fuel 700+ hp CR Dodges.
C-ya
mick
Try anything
Aug 15, 2006
482
C-ya
Thanks Mitch - Ill try Darkside First and go from there. Thanks yall for your input
SmokeShow
6,818
Lawrenceburg, KY
Some reading from CompD about Darkside's pump on a CR Dodge.
700rwhp w/ Stage III
Darkside Dieselworx Site
Hope that helps a little. As I said, FloorIt's new Stage III is supposed to support the same kind of power but it's been a couple months back and forth and still can't get one ordered. Frustrating for sure. :mad:
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
As far as Darkside his truck suposedly makes 700 hp on a single but he runs 13s in the 1/4.:screwy: Also he has proven on some website that he himself is far from honest.
If it where me which it is not. I would call Industrial Injection as they are the only people that have actual proof there mod really works.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
The Industrial Injection pump works good.
But here's the thing:
None of them actually increase the bore or stroke of the pump. So can't be doing anything that is all that trick. My guess is just opening passages, and doing the porting thing to the Regulator.
mick
Try anything
Aug 15, 2006
482
My thinking there Pat. Might try it myself then. Anyone heard of this guy?
http://www.relentlessdiesel.com/forum/viewtopic.php?t=19
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
EXACTLY
Doge and GM:confused: As Johnboy pointed out they are different Cp3s Close but not the same!
Yes Mick and it has been disscussed many times;)
mvnvltn
Part's Limit Tester
Aug 22, 2007
463
45
Sykesville, MD
I have a spare CP3 on the bench, I am debating of doing the full mod to it.
I am a masterdebator. :D
Is there anyother advice on modding one other than what is described in that link?
