Mitusa??
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
What are everyones feelings on the MITUSA? I am about to pull the trigger and I would like some input from you guys! -Jeff:hug:
fordt
Think Done Deals
Jan 3, 2007
377
Vero Beach, FL.
www.abcamping.com
Keith liked his last time I talked to him about it. I know they put out alot of fuel. Personally I think running a FASS, or something like that is plenty. Just my thoughts on the matter. How much do the MITUSA pump run?
SmokeShow
6,818
Lawrenceburg, KY
I love them (well, the idea of them - I haven't actually ran one or even know some one personally who has) but got tired of waiting after a month. My friend has stuck it out and now about 2.5-3 months later he still doesn't have one. :eek: His dad's should be here shortly though as it's going on a dual CP3 truck and evidently those were made first. Evidently Opie is having trouble getting the pulleys done by the machine shop he uses. Can't imagine it's that slow of a process though. :rolleyes:
Ultimately, I'd like to have one though as I like their apparent abilities.
C-ya
C.A.P
Feb 16, 2008
103
I run one and make a bracket for the dual cp3 kit too. Its a sweet pump. Its unlimited in demand . You will not run short of fuel. It depends on your valve setting you want to use. With one cp3 I held 21k rail all day long.
C.A.P
Feb 16, 2008
103
First one is on a dual CP3 set up the second one is on a single cp3 set up !
slowlmm
Mar 2, 2008
2,582
46
so cal
thanks for the picks with the dual cp3 setup and tht pump where you able to sustain 23,000 plus constant or did it still drop ?
C.A.P
Feb 16, 2008
103
23:(...:rofl:.......................Well lets just say the Regulator only lets us read so high ! But 26 k is done easily !
juddski88
Freedom Diesel
Jul 1, 2008
4,658
125
Chesterfield, Mass.
how would this compare to the abilities of the Wicked Diesel Eliminator kit? Holy fittings though with the MITUSA wow!! could a flex line be used instead? something with less right angles? i am trying to decide how to setup my 01 now for fuel and this is a great option.
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
I have over 100,000 miles on my MITUSA on the original belt, all the fitting you see is for it you threw a belt it would bypass......on a race truck or weekend truck I wouldn't bother with the bypass'.....the "small" pump with make up to 80psi with a WOT shut off on the return line....a nice feature is that it is on the other side of the FICM so pressure is not an issue.......and they are silent!
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
Well I am far from mechanical inclined, I did it in my driveway, half in the dark, by myself, with basic hand tools and a rum in one hand....IIRC some wrenches, Allen key set, utility knife, adjustable pliers, and zip ties is all you need....NO WIRING!!!!!
And my twins were in the way.........
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
Single or 2 cp3's..........got any pics you could post :hello:
