Help: MITUSA not priming?
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I went to prime my system to FINALLY start the truck today and I cant get it to prime with a drill??? isn't this how they are supposed to be primed? I currently have a stock tank in because my first fuel cell was mis-shipped. I have a 1/2" line from the sump to a donaldson water separator/filter setup and then it continues to the MITUSA. all pushloc fittings. I put my thumb over the fuel filter head to verify suction and I was not getting any. there are no leaks in the hose or fittings. I opened the pump and it seems fine. i tighten the back cover until the shaft starts to show resistance.
any ideas?
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
yep, and i tried it the other way too just to make sure i wasn't crazy. did you use the big (4") pulley at the driven pulley or did you use the small one (1" approx)?
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
well, I asked because the pump i bought used came with 3 pulleys, the drive pulley, the large pulley, and another small pulley (which i assumed was for dual cp3 applications for higher flow)
slipclutchms
427
Tim, I never got a call yesterday.....try pressurizing your fuel tank with shop air to push the fuel to it.
Spink
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
I have an electric lift pump on a switch with a check valve-by pass set up to prime my system, works every time. When I change the filters, I don't even pre fill them just flip the switch and crack the bleeder screw.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Looks like I will have to install an electric lift pump too, I tried to fire it up yesterday and the Mitusa isnt pulling anything while cranking. you can hear it gurgling like it wants too. but it's just not enough RPM i guess.
slipclutchms
427
go to advance and put a "mr. gasket green" pump on there. They cost 40 bucks and that should work. Green pump is for diesel
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
try filling the lines with fuel by sticking the back end in a bucket of fuel and siphon it to the front. Have someone stick a finger one the end in the bucket then hook everything up and try it out;)
maine04max
Dec 11, 2008
1,009
Tim .... get that thing fired up will ya . :roflmao:
ps got your message and ill be in touch
slipclutchms
427
I was saying for a temp solution just to get it fired....once you get everything running and primed I figured you could pull her off. 1/8" wouldn't be a restriction would it?? ;)
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I got some old Kennedy pumps from Ben to wire up for now. If it ends up being the issue ill buy the black laing from tony and keep it on a momentary switch. I have a feeling its the cp3 though.
