Misfire oh no
fast03
1,201
61
Rancho Cucamonga
Well my truck has a problem. The other day after coming back from a 1800 mile trip to Utah/Colorado from Cali. I got in the truck after a few hours and it had a misfire, but it cleared up in a minute and no CEL. Yesterday started the truck, went 10 miles shut it off no problem. Restarted after a couple hours and I have a CEL. I pulled a p0380,p0101,p0303,and another p0380. Have not really run it hard lately but the periodic misfire in cylinder3(p0303) is worrisome. I am thinking a glow plug problem. I do have a bad balance rate (6.5 in drive) on cylinder 1. p0101 in mass air flow. Truck seems ok for power after warm up. Any Ideas?
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
i would address the glow plug issues first and see what that does. has the controller ever been replaced?? does it smoke considerably on cold start up and take a while to clear up??
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
X2
Fix the glowplug issue first, then see what happens. I don't think the codes you have are related, but you never know...
Cali truck right? Odds are it's one or more glowplugs gone bad.
fast03
1,201
61
Rancho Cucamonga
Thanks guys I am looking into the harness. I pushed and pulled on it and no code this morning. Can a glow plug problem cause a misfire?
fast03
1,201
61
Rancho Cucamonga
X2
Yeah Lawrence its a Cali truck. Should that make a difference with the glow plugs?
WanaDmaxsub
Feb 17, 2007
644
Yes, the LB7's are different fed to cali. Cali trucks usually have glowplug issues, fed trucks have controller issues. IIRC i've had a P0380 code pop-up every spring for the last 3 years. But I have never had a miss fire code!
fast03
1,201
61
Rancho Cucamonga
Second day is a row no codes, I guess trucks getting old and things are loose. I will have to watch it. Raced last night and no misfire.
WanaDmaxsub
Feb 17, 2007
644
The P0380 will come and go.
IIRC, 2 consecutive calls for glowplugs (cold starts) and one or more doesn't work the CEL will light.
3 consecutive starts without a call for glowplugs (warm starts) and the light will go off.
