Misfire code p0301,p0101
Vernon Stoltzfus
Nov 30, 2012
24
Very puzzled, LMM is throwing p0301 p0101 codes and going in reduced power mode. Idles fine, knock/msfires at 1000-1500 rpms. Has a white smoke haze. Compression test were all between 350-385. Any ideas where to even start?
Vernon Stoltzfus
Nov 30, 2012
24
Swapped injectors 1 and 3. No more p0301 code but still has the same knock/misfire.
Also changed crank position sensor. Bout to pull my hair out, makes no sense at all.
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
low compression would be white smoke/haze like you mentioned, black smoke is usually over fueling(usually), and white is typically poor combustion, IE low compression, not enough injection pressure, cold cylinder. You have all the correct components to due the magic shrinking rod trick.
Vernon Stoltzfus
Nov 30, 2012
24
All the low compression motors I've worked on before had white smoke at idle or cold but it always changed to black smoke/high egts at full throttle. But smoke aside, cylinder 7 was at 350, all the others were right @ 380. So why was cylinder 1 picking up the misfire? Also it has distinct miss/knock at 1200 rpms. Would marginally low compression make a motor knock?? Thanks for your input guys
Kappa9012
Aug 5, 2008
694
Peoria Il
one thing you might try is killing one injector at a time. as you go cylinder to cylinder usually you'll hear the cylinder cut out, if one cylinder doesn't change the engine operation when you shut it off, likely you've got a bad injector.
Vernon Stoltzfus
Nov 30, 2012
24
Did that via Efilive, didnt seem to make a difference which one was turned off. Anyone have a complete LMM motor for sale? :(
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I thought gm spec for low compression being an issue was 300 psi and below??
I doubt 350 psi is your issue. I'm still betting you have a fuel/injector issue. What are your balance rates looking like?
Vernon Stoltzfus
Nov 30, 2012
24
You are correct, below 300 or an individual cylinder that is 50 +/- from the average of all 8 is what my manual tells me.
Balance rates look great, they range from -1 to +2.5
Vernon Stoltzfus
Nov 30, 2012
24
Update...
Fixed maf problem, that solved the reduced power mode.
Not getting any codes at the minute but still have a bad misfire.
Vernon Stoltzfus
Nov 30, 2012
24
Still fighting this issue, put in new ecm and crp sensor, no diff. Put it all back together and ran it for awhile. Now i have injector 1,4,6, and 7 control circuit codes. Wiring harness maybe?
Kappa9012
Aug 5, 2008
694
Peoria Il
start looking for a ficm, even if you just pull one off another lly to try. Seems like it's taking a shit on you.
