Middle tire wear
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
What psi should i be running in the rear tires? Iirc they're ~65 psi. They're wearing in the middle with the outside lugs showing plenty of life. Thanks in advance
Sent from the drivers seat of an 06 dmax
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Middle wear means over inflation. The easiest way to find the correct tire pressure is to make a chalk line across your rear tires then change the pressure until the chalk line wears evenly. Dont do it on the front just because those are your steering tires.
SoCalMike
758
SoCal
About 45 psi rear. 55 front. that is what i run in mine. 285/70/17's
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
Took it from 70 rear to 60 rear, left front at 60 as well.
Edit- tires are toyo open country 10 ply
Dirtymaxx03
3,109
Dont run full pressure in those tires unless you tow, or they will wear funky. I got 45ish in mine and it helps the ride a lot
