Question: mickey thompson
ku 808
164
I just bought a set of mickey thompson classic 2 rims 18x10 what size of tire to run? my tuneing is set up for 265-75-16 and I really like how my truck rides and I will not level or lift my truck any help will be appreciated
c_mo88
Jan 6, 2011
Biloxi, MS/Shaw AFB, SC
a 10" wide rim is kinda wide for a non lifted truck...i would say a tire that is 12.50 in width is perfect for that rim...you could even go wider but i think you are gonna run into a problem with a 10" wide wheel on a non lifted truck...MAYBE if it was leveled and some trimming, but then offset plays a role too
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
a 305/50?/18 tire should fit pretty good without cranking the t bars. the backsacing plays a big part too
ku 808
164
thanks everyone I bought them cheap $350 with 325/65/18 nitto terra tires with 50% thread now I feel it was a bad deal bolts up right in the middle 5 inches on both sides:confused:
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
thats a big tire.....just replace the front shocks with some longer ones and crank her up a bit. the longer shocks should take care of the bad ride usually associated whith cranking the bars. your going to have to do some trimming with a wheel that wide. a 33" tire would look sweet
