Question: Mercon V?
Laynesman
Oct 27, 2013
Can I use 'Mercon V' automatic transmission fluid for my 08 duramax?
It says use in auto and manual transmissions and power steering on the label, and I realize its probably not the top of the line as far as products go. I just need to know if it is okay ( not detrimental ) to put in for now. Thanks for any help!
calewjohnson
Aug 17, 2013
Left Coast
I would say yes, as long as it meets the TES-295 requirement or whatever your model year requires (IIRC DEXRON VI).
I know for me, I need DEXRON III, the dealer put in VI and said it would be fine, but for my model year, Allison specifically says not to use the VI. So I did a double flush with Mobile Delvac ATF.
Good luck.
Cale
btfarm
you know
Nov 25, 2010
387
Sandwich, Illinois
No. Do not use it. And for that matter Allison does not recommend Dex VI. Use TES 295 approved fluid. Transynd or Mobil equiv as mentioned. Unless yo have a built trans.
Sent from my SCH-I535
calewjohnson
Aug 17, 2013
Left Coast
Actually, DEX VI is what you will get when you go to a dealer nowadays. Allison put out a serial number list with a date starting in 2007 that was OK to use DEX VI since GM switched from DEX III. Factory fill now is DEX VI.
Trust me, I argued with the yahoos at the dealer, since DEX III is the recommended fluid for all 5-speeds.
Cale
Magnus
Jun 22, 2013
144
The Dex 3/Dex 6 issue has to do with seal material used. At a certain point they changed seals and now Allisons are Dex 6 compatible and come dex 6 from the factory, hence the specific mfr date referenced.
That said as long as you're changing do a TES-295 compatible fluid in trans transfer case and power steering and be done.
Magnus
Jun 22, 2013
144
Dexron 3 is the Chevy fluid, but Allison has their own specification known as TES-295. If you flush and fill twice with any fluid that meets TES-295 you'll be able to run that fill for up to 100k miles and even at that point the fluid may still outperform other lesser tranny fluids.
The official TES-295 is licensed under the name transynd.
There are other good fluids too, and I personally run Schaeffers 204SAT bought locally for $130/5 gallon bucket. It has the best cold weather startup performance I've ever seen and at that price I did the whole truck (trans, xfer case, and steering).
Most people here will tell you to buy some transynd, and that is the official word from Allison.
btfarm
you know
Nov 25, 2010
387
Sandwich, Illinois
Mobil has TES295 synthetic and is Allison endorsed. It's a bit cheaper than Transynd but not much. I paid $225 to my door for a pail but I know I have the right stuff in it.
