Merchant motor mounts
maine dmax
Mar 28, 2009
127
Couldnt figure out where to put this, so i put it here. At what point are most guys going with aftermarket motor mounts? (merchant) Thanks
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
You can save $ by drilling out your stock units and running a bolt through. Lot of guys have done this. I bought the Merchant mounts a few weeks ago and they will be installed when my built motor goes back in. FWIW my stock driver side mount cracked at around the 600+ HP mark.
gmduramax
Shits broke
Jun 12, 2008
4,068
245
Nor cal
When I ran 600hp the stock mounts were fine. When I went to about 700hp my exhaust kept falling apart and moving. I'm in need of MA mounts.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
We have pulled out mounts in relatively stock trucks that have been destroyed by new england climate and fallen out in pieces. Also, have bolted some that have been partially ripped already between 400-600 hp
1,802
550 broke my stocker mount. I wont be able to use Mm's in the little truck, though.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
The issue with bolted mounts in a high HP application is that many times they still wear through. They will last a while though, more in non competition trucks.
ripmf666
15,123
14
47
Wentzville Mo
I did the Johnny boy bolt job on mine when I did the build. That was almost 5 years ago this July and 79k miles as of right now. If you want to save some coin can do that or the Ma mounts there nice. I also sell those if I can help you just pm me.
maine dmax
Mar 28, 2009
127
Ordered a set of merchants, should have em in this next week, provided I have time, getting ready for mud run season now
