MBRP or Magnaflow?
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
Lookin for a 4" down pipe back exhaust system for an '06 LBZ. It seems like i can get a stainless Magnaflow system for about the same price as an aluminized MBRP system. Is Magnaflow diesel exhaust any good and what kind of sound do they have compared to the MBRP system?
'03duramax
I love cheer******s
Sep 16, 2006
190
WA
I had a 5" MBRP on my ccsb, it sounded great and was pretty cheap. I would buy from them again. Hard to imagine an SS 4" being same as an aluminized one. Weird.
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
I have never had a problem with either of these brands. I use to install up to 10 Magnaflow kits a week and they always went together perfectly. Now I use MBRP on everyones trucks. The kits are cheap and install fairly easy.
Your good to go either way. But I would go with a stainless Magnaflow if you can get it for around $350. Both kits sound better without the muffler and a 3" downpipe.
Sent from my DROIDX using Tapatalk
Tyler@MPF
Oct 28, 2008
55
Both are great, I wouldn't hesitate going with a Magnaflow. I run one on my truck and have had great luck.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
I noticed that the Magnaflow is a two piece tailpipe vs. the one piece in the MBRP kit i was looking at. Is it really a bad thing or is it just a little harder to get things lined up right?
dirty-b
KCCO!
Jun 5, 2010
337
Central MN
I have the 5" magnaflow on mine. Love the sound. My pipe has cracked next to the back hanger. I like the two piece tail pipe because you can take it off if you want it to dump behind the axle.:2cents:
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
idk about the magna flow but my MBRP 5" is pretty loud if ur around the bed but all you hear in the cab is some turbo whistle :D
Burn Down
Sep 14, 2008
7,092
Boise Idaho
That is where mine cracked as well, also has a crack in the center section where the spring hanger welds on. Not enough support from the hanger where they weld it to the pipe. I extended the hanger around to the bottom of my pipe to give some extra support.
The roads are quite a bit rougher than the lower 48. Probably explains mine cracking out.
The MBRP is a little louder imop.
