max tires size 4 a 2500HD
JS2TZU
Dec 3, 2008
287
Kauai Hawaii
I have a 2001 2500HD crew cab 4x4, with the front torsions cranked up to level the truck out. I need to know what is the max tire height that i can get under there without it touching? It will be on the stock wheels.
thanks in advance!!
The Neens
BFD
4,596
Monrovia, Ca.
A friend has 305/70/16 on his '02 Chevy...Didn't have to trim the lower valance...Chevy might have more clearance than GMC, I had to trim my '05 and '07 GMC for 285s...
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
I also had trimming and tied my Ebrake cable back to fit 285's with just cranking the bars.
Seems to me the Crew Cabs sit lower up front than the ext cabs. My buddy had less trimming, more rooom on his ext cab.
JS2TZU
Dec 3, 2008
287
Kauai Hawaii
so 285/70/16s or 285/75/16s?
I gotta be dead on cause the have to "special order" the tires and if there wrong i cant send em back. living in the middle of the pacific ocean is a major pain!
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
is this for your dually ? if so you cant go that wide on the rear duals without spacers . if it is for a single wheel you can fit a 285/75r16's with the bars adjusted, 295's with some trimming . .
racinmike77
Sep 14, 2008
1,029
MD
Josh has 315/70/17s on his truck with rims off of a newer cummins, similar to H2 rims id imagine.
JS2TZU
Dec 3, 2008
287
Kauai Hawaii
no these will be for my daily driver I have a 2001 2500 HD 4X4 CC.
