Max Hp Capacity of an LBZ vs LLY Turbo?
nskyline34
Nov 27, 2010
25
Seattle
I've got my LBZ torn apart right now for sticking vanes, and I'm considering trading a buddy for his LLY turbo. I would port it and clean it up, but otherwise it would still have stock wheels in it etc.
I'm wondering what the max hp difference is between the two?
I'm considering doing compounds down the road so I will likely keep my eyes open for an S475, but that could be 3 months or 3 years down the road. In the mean time I'm just wanting something that spools really nice and will will tow well. And I think either turbo with porting and some up pipes will do really well.
Anyone know how much more the LLY snail flows compared to the LBZ one?
Also while I have the turbo out, is there anything I should do now to prep for twins down the road? Just a thought I had.
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
I just did twins on my LLY. I don’t want to tear back into it as things fit really tight in terms of clearance. I’d make sure you have all the maintenance nuance things done and have a good base to start from before going twins. Otherwise, it’s not that bad. Most changes happen when you install the kit so you won’t cross that bridge till you do it. On the LLY, studs and gaskets are a must. If you have the $$, rods are good for LLY, but you are more likely to need pistons on the LBZ.
nskyline34
Nov 27, 2010
25
Seattle
Good to know thank you. I did compounds on my Cummins I had and I absolutely loved them! I wouldnt being doing studs and gaskets until it pops though - not looking for anything crazy hp wise - just 500whp that runs cool would be good with me...I've got a race car with 1,500hp that can put a smile on my face otherwise. lol (Not to mention that's why there's no extra funds for HG's or studs or pistons! :roflmao:)
How well does yours tow? I was basically thinking about a setup just like yours so I'm curious how well it tows and what the hp #'s are and EGT's?
Bdsankey
4,152
1,262
Larsen, Wisconsin
The stock LBZ charger will spool the best out of the factory lineup. As for max power potential between them, that I do not know. The LBZ compressor/turbine is smaller than the LLY but they (LBZ) have proven to make over 500hp with just a built trans/tune/exhaust time and time again while still maintaining great driving manners.
The factory head bolt is NOT the reason early trucks have head gasket issues. Factory head bolts are sufficient to the point where I'd be more concerned about factory LB7/LLY rods before the head lifting. The issue with early trucks is the gasket itself. Early gaskets were crimped together. Overtime the layers of the head gasket (they are multi-layered steel, MLS) would shift and cause them to no longer be sealed. The newer construction method is to actually rivet the layers together making them almost impossible to shift between each other. With that said, studs are a worthwhile investment when doing head gaskets as you already have to buy new fasteners since factory head bolts are torque to yield. I just don't want there to be any confusion as to why things fail.
As for LB7/LLY rods, I wouldn't condemn them on a compound unit for something like a S475 over the stock VGT. A good tuner will know what to do in order to give it the best shot at a long life. Larger injectors do help keep them alive by reducing timing/injection duration thus reducing cylinder pressure and lessening the loads on the rods at the same power level.
If you're looking for the ULTIMATE in terms of a towing experience, nothing beats a S475 over stock kit. At the ~500hp mark I wouldn't be too worried about the bottom end, especially with quality tuning. The normal failure point on the LBZ is the pistons. It's a crap shoot as to if/when that happens. Some guys never have issues and beat the trucks like the truck owes them money. Other guys have had pistons crack with a mild or even no tune just driving around.
nskyline34
Nov 27, 2010
25
Seattle
Ok, sounds like I will just keep the stock charger then! I'll have to get it ported and cleaned up and then I'll toss it back on...and enjoy vanes that actually work! lol
We will see if I end up doing the compound setup or not - I would either buy a used charger and fab my own, or (and what i'd rather) is find a setup that someones selling. I dont have any goals/plans for the truck to make gobs of power, and I'm surely not going to push it to where I need to tear into the internals. If something happens and I have to tear into it, then no big deal. But I dont want to push things to the point where its a ticking time bomb lol
So odd how the LLY charger is bigger, but flows the same amount of air?! I wish I could get a compressor and turbine map for both of them. Curious as hell now. lol
