Alright guys I got one that's kickin me here, its an 01 chevy duramax customer complained that it need injectors when he showed up it had huge amounts of diesel fuel in the oil. Drained the oil and put a reman set of injectors it in. Got it started and took it for about a 25 miles test drive, got almost back here and pulled over looking at the balance rates and the truck was missing horribly bad. Made it back and looked down and had little no oil pressure. Shut it off got in inside and fuel was running out of the breather tube. Started it back up and the oil fill cap had a ton of pressure on it. Took a light and looked down in there and could see diesel fuel running into the oil fill. My thoughts were CP3. I put a tech II on it and tried maxing the pump out and it would only make 13,xxx when I commanded it to make 23,000. Put a new pump on drove it again everything seemed good. No more pressure, no more fuel in the oil fill either. Now heres the kicker; I get a call this morning he drove it an hour home and he got home and its doing the same thing, he said the oil is completely over filled and fuel is coming out of the breather tube again onto the ground.
What the heck am I missing?
