Massive antifreeze leak
DirtymaxBlake
Dec 18, 2014
i have a massive antifreeze leak and trying to figure out where its coming from its leaking at the front of the truck almost as fast as i pour it in when the motor is running it looks like its coming from the motor i don't know if theres any freeze plugs on the front of the motor or if the water pump could leak that bad there was water only in the system because i had a slower leak and was loosing about a gallon a week it got cold but but as far as i know the water was drained and a 70/30 antifreeze to water was put in drove fine for a couple weeks and then huge leak and massive power loss
schulte
Jul 31, 2010
449
CT
If you can't just see where it's coming from, pull the lower radiator hose off the water pump and cap it off, fill the motor from the upper radiator hose to start, to determine if it's coming from the radiator or the engine.
