Manual Boost controllers
diamondshocks
crash skippy racing
Feb 15, 2009
115
Fargo, NS
www.diamondshocks.com
12secondhandshaker
<---Stock trans
Jan 21, 2009
146
Sparta, MI
Tom, I have all those parts on the shelf if you would like me to make you one?
Its just brass parts and a needle valve to adjust the ammount of boost the wastegate sees, therefore allowing you to run higher(or lower) pressures.
2,094
Just figuring that if all these mods Ive got in the hopper do what I hope, they are going to render the boost valve obsolete, and I should probably use something adjustable.
Hmm..now that I think about it, I read a while ago on DP where someone was going to use an air compressor regulator and a length of hose to do the same thing. Hell, that shouldnt be all the tough to build. Calibrating it would be interesting.
diamondshocks
crash skippy racing
Feb 15, 2009
115
Fargo, NS
that is basically what the turbonetics one is.
http://www.citydiesel.net/turbonetics-variable-boost-control-kit-p-237.html?cPath=32_65
2,094
Tom you really dont need it if you have the boostvalve already.
Can you explain, Vaz? I figured if the mods I'm doing allow the turbo to make more boost than the 32lbs safelimit then I would come up on the wastegate easier. I have no idea what boost level the PPE valve limits at.
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
i cant get over 30 but thats with a tranny safe tune. i would like an adjustable so that when i make more than 32 i can turn it back a little
