Mahle Wavestopper Grade D Head Gaskets
Chilly
101
3
I found part numbers for Mahle Wavestopper grade C head gaskets. Trying to track down the grade D part numbers.
I found OEM, but not the Wavestopper type.
Can anyone help me out?
boominator
168
5
MI
I have looked in the past I do not believe they make them in a D.
5,610
Wavestoppers are only in C grade.
if you need a D, get the regular Mahle.
how much was that block cut you need a grade D? thats ALOT of gasket to put on something that will be seeing good power.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,438
444
Central OH
I can't remember where I read it now, maybe on the package itself, but I thought the grade D was a C thickness but an overbore gasket
5,610
nope, they are .010 thicker than a C. they are meant for "overbored/decked" but thats a broad discription. i know the mahle and lml hg are good for .040 bore overs. im guessing if you run stock pistons and deck the block more than .005, this is where the grade D can come into play for a shop that is just trying to get an engine slapped back together. I would rather cut the pistons though than run the grade D.
ikeG
Oughta Know Better
Apr 19, 2011
2,447
139
Western PA
www.facebook.com
We ran D's on an engine for a couple seasons at over 1k hp. That engine is still going strong in a 900hp street truck.
Sent from my SM-G960U using Tapatalk
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Whats the difference from the regular Mahle/Victor Reinz vs the wavestoppers. I though they were just all the same?
Wave stoppers have multiple little metal rings that get pressed into block surface. Almost like small o-rings. They actually leave imprints on the on sealing surface.
rcr1978
790
Spring Creek, NV
Huh shit :confused: So these are only available in C's? The A&B ones I got had the little rings your explaining can someone post up some pics of The wavestoppers vs the normal Mahle/Victor Reinz ones?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
My eye has not been able to spot the difference between the regular gaskets and wave stoppers. Either way, I've blown both on my old truck at 1180whp with standard ARP 2000 studs at 85psi boost. They'd last 2-3 months before they were toast. I just started using the cheaper gasket since they lasted the same. The regular gaskets have the same little wavy rings as far as I remember.
