Mahle Cast Piston EGT
Chilly
101
3
What’s the maximum EGT guys are running the Mahle cast pistons? Did a couple google searches and came up with nothing.
Blackmax123
683
central Pennsylvania
Are you looking for the max egr for and extended time period or shot spikes while drag racing or sled pulling?
I dont even look at my guages sled pulling as by the time I'd realize that they're scary high itd be too late to let out of itanyway. I actually don't even use guages as I unplug my cts2 do I can datalog.
Chilly
101
3
Just looking to be conscientious whether I am towing or fooling around on the street.
5,839
Turbo/valves will be the down fall, not pistons on egt. Cylinder pressure affects the pistons much more than the heat these days
13,714
776
What James is saying is that high EGTs don’t really affect pistons as much as they affect exhaust valves and turbine wheels. EGTs are a measure of the exhaust temperature; it is not a measure of cylinder temperature.
Chilly
101
3
Thanks Josh.
So what’s the point of everyone installing EGT gauges if the temperature doesn’t really matter? I just wanted a good number to stay under for fooling around on the street with a 700-800HP tune. With my set up I would assume the Mahle cast pistons can still be cracked or overheated, leading to a hole in the piston.
When you guys were talking about valves, are they prone to fairly at this HP level? The Wagler heads I have, got aftermarket oversized valves.
Why is heat an issue with turbo wheels? I’ve never heard of this being an issue.
Just a little confused is all...
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
Link from a recent thread.
https://www.duramaxdiesels.com/forum/showthread.php?t=82625&page=2
Thanks Josh.
13,714
776
Thanks Josh.
Because people are ignorant and usually don't care to learn. I'm not saying installing an EGT gauge is bad, but it isn't really a good way to judge what is safe for a piston. I cracked a piston in my LBZ with compounds over stock years ago, and the EGTs never got over 1350. That is what anyone will tell you is a safe number all day long. The thing is, on just a stock turbo, that tune would have see well over 1600 degrees of exhaust temp, but because all the fuel is being burned inside the cylinder, there isn't as much heat coming out the exhaust. Does that make sense?
Bdsankey
4,170
1,276
Larsen, Wisconsin
Thanks Josh.
Nobody said it doesn't matter. For short term the pistons aren't the weak point with temperature. If you're pulling grades I wouldn't stay above 1300-1400 for long. I know when we towed my LLY out to Denver for DPC we ended up running 1300-1400 up a few big grades (grossing 23,880lb) with my LB7.
