LB7: MAF voltage table
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
alright, who has a voltage scale table for a 5 inch intake that i can steal? i am trying to reduce the smoke output with my 60 overs. i have searched and searched and i cannot find what i am looking for. id just as soon have the sensor read right (or as right as possible) rather than just start tweaking the flow limited table to work with inacurate readings...
Thanks guys!
Killerbee
Got Honey?
Thanks guys!
Multiply your existing values by the ratio of x-sectional areas. That is a place to start.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Thanks guys!
I have one that has been working pretty good , but if you increase voltage the smoke will increase due to the ECM thinking there is more air now , unless you have the MAF limiting tables maxed out to " mask " the table not being calibrated right ?
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
trent, right now the airflow limiting tables are so jacked im just going to import a stock table and start over, begining with the voltage table to get the reading as acurate as i can. then i will start tweaking the limiting tables again. if you dont mind i'd like to see what you have. :)
TrentNell
Jul 7, 2008
7,543
slc tuah
I can show you a few things to try , send me the tune and ill make some changes and see if they get you on right track . [email protected]
