I have 2 things to add here. First off, The efects could be very noticeable, especially if the sensor is close to the compressor where there is alot of turbulence. If your tuning is still using the MAF limiting tables the resulting lower-than-actual airflow reading will seriously hinder performance. Granted this could be tuned out, but at a resulting loss of total tuneability (read smoke prevention, and turbo response). The intakes that I have built, when I install the bung for the MAF sensor, I mount it slightly turned in the direction of the vortice within the tube...I have had good results with this. But keep in mind, I mount my sensors in the middle of the longest straight section of tubing possible...as close to a laminar flow as possible.
With that being said, unless you are using the MAF limiting tables in your tuning, the airflow sensor is not really required at all on these trucks. Most customers trucks that I tune, who doesn't make a big stink about smoke, I normally dissable MAF codes and give the limiting tables a generous amount of tweaking to alow for more fuel down low.
