LLY: MAF recalibration needed?
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I put an AEM CAI on a while back and I know this is going to change the air flow drastically compared to stock I'm sure. I understand this could possibly cause a lean condition. Does the MAF sensor need to be recalibrated and if so how do I go about doing this. And at what values? Any input is appreciated. Thanks
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
From what I have learned on here and at school that as long as the new CAI is not larger than the stock tube running from the filter to the intake to the turbo that no recalibration is needed.
IRC the AEM CAI is not larger but I could be wrong.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Ok I guess that would make sense, it is a metal tube not sure if that makes a difference.
2005 Chevy LLY
Extended cab short bed 4x4
Sinister EGR delete kit
S&B turbo mouth piece
Sinister intake tube
PVC reroute
4inch straight pipe
Edge CTS juice with attitude plus hot tuning
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
I've never road in one that needed re-calibrated but I hear that they run like absolute crap and have absolutely no power what so ever. So as long as that is not the case I would say that you are completely fine.
I wouldn't think that build material would affect this in any way.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Ok thanks guys I won't worry about it then haha
2005 Chevy LLY
AEM CAI
PVC reroute
4inch straight pipe
S Phinney
4,008
Quncy, Fl
The only way to know if it needs adjustments is to log MAF. It should read 40 gr/sec at idle and 400-500 at WOT. If less than 35 you will feel it start to be sluggish.
Sent from my XT1080 using Tapatalk
