Been data logging MAF pids along with fuel while staging and launching (I have a 6" diameter intake).
At 25% throttle position (2094rpm, 45mm of calc fuel flow, around 130mpa of rp, 1250us pulse, holding the brakes hard while staging) MAF voltage is 1.8v and lbs/min shows around 13.
At 100% throttle position (2400rpm and rising) calc fuel flow drops to 32.8mm, rail pressure drops 123mpa, MAF voltage is now 1.0 and lbs/min bottoms out at 6.3.
I have not re-scaled the stock LBZ MAF table yet. Anyone have a good method to help dial this back in?
Here is what I do.
You need a stock air inlet tube with the MAF mount in it.
Use a silicone reducer or duct tape to seal it to the end of your intake tube.
Now log you need to log the MAF voltage.
Use the DVT tool to raise 100 rpm at time.
Then log MAF flow and voltage.
Write down the RPM, voltage, and grams per second for each RPM.
Example My stock 07
700 RPM 35.2G/s .8v
800 RPM 37.0G/s .8v
900 RPM 47.8G/s 1.1v
1000 RPM 59.0G/s 1.3v
1100 RPM 65.2G/s 1.4v
and so on
Remove the stock MAF mount and then mount the MAF back in your intake.
Repeat the same test.
The actual flow should change very little. But do to the larger inlet Diameter it will read off.
Now say for examples sake at 1000RPM you had.
Write down those values just like you did for the first test.
1000 RPM 24.1G/s .47v
Your stock MAF flow reading was
So go to table B0201 and correct the voltage from the new intake to read the Grams/sec of the stock one.
This should get you close.
