What should the MAF sensor read at idle? Ive heard 40 g/s but mine is reading 37-38 ish at idle with an LMM intake on my LLY. I had to modify the LMM intake to fit the lly maf sensor, so I'm not sure if it should read exactly 40g/s or not
Does the truck feel laggy driving ?
The reading you get comes from the interworkings of three items. First it uses the velocity if air flow. The ecm uses a voltage to the MAF. Finally the air cools the heat applied to the MAF which in turn gives a analog signal that is interpreted into a number reading. That 70-80 number had more velocity which is evident from that reading in itself. There is or was a difference in sizing of some parts involved that resulted in that velocity change.Shane what was funny, is the 70-80 was showing on my LLY airbox. ATP said their race tuning will run with either airboxes with no tuning adjustment made
That kinda makes sense, running LLY box setup with LBZ scaling. Was it smoky before?
