Lowering T bars
Trotorx2
699
71
Beaumont, Texas
When lowering the T bars is is necessary to get the front tire completely off the ground or can you just get the weight off of the front end?
I'm going to the track tomorrow night and I have a bottle jack that will get the front most of the way up but won't get the tire off the ground. Will this be ok to try?
I have my All Seasons centerlink brace installed and want to see how much it helps.
5,839
put the jack under the frame, not the lower control arm when you lift the front end. otherwise lifting it does you no good. get as much weight off the torsion bar as possible otherwise you run the risk of snapping the bolt off.
Trotorx2
699
71
Beaumont, Texas
I know it is best to get the tire off the ground but not sure if this jack will do it.
I know to put the jack on the frame. With the tire off the ground the bolts turn easy.
I guess I will leave them alone and just see how the front end does with the brace.
Duramax5
duramax freak
Sep 15, 2011
417
West Texas
I would definitely lower them down b4 launching because u can bend that brace in a hurry if u don't
AdaMax
Nov 26, 2010
412
Caldwell , Oh
You can always jack it up a little tighten them up then reset the jack a couple times to have the least amount of stress that you can get on them .
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
I wouldnt want any part of the tire on the ground to crank the t-bars back up. Those torsions bar bolts are a soft bolt too. They can be very fun to get out to replace too.
