I got a wild hair today and decided to lower my truck a bit. I have the RCD 6" kit so I put the truck up on the lift and loosened the torsion bar bolts until they were just snug enough so they wouldnt move when the truck was in the air.
I put it back on the ground, it has a pretty decent rake to it now. I am gonna try and put a smaller block in the back, hopefully it will be a bit more level after that. The only problem i have at the moment is the RCD bumpstops are huge, and the lower A-arms are riding on them.
I am going to try and put either some Rancho or Tuff-Country bumpstops on in their place. Maybe it will ride a bit better. The tires rub pretty bad on anything more than an easy turn, i think it has to do with the offset and width of the rims. But I am trying to find some 3rd Gen dodge wheels and some 33's to put on instead.
I did my first 4wd boosted launch with the lower setup, ALL of the jumping around is GONE!!!! I took a co-worker of mine for a ride after work, boosted it up to 10lbs. and let her rip, the front tires squealed and it took off straight and true!!!! I am happy as hell!!!!!! All I need is the new tires and rims and the bumpstops and I will be in business!!!!!!
12's HERE I COME!!!!
