Lower valve covers
valleyduramax
233
Ottawa ON Canada
Just wondering what if any tricks or tips there are to removing the lower half of the valve covers. I am tearing top end of motor apart and am now at a standstill as the lower covers on both sides are stuck on. All bolts are removed and can't see anything holding them from coming off. Now with that, 7 out of the 8 injector hold down bolts twisted off when removing them. All I can assume is that the bolts are bound up against the bores and not allowing cover to pop off. I am at the point where I may just cut the covers up to remove as they are slowing progress to a standstill. Any other ideas?
Sent from my SM-A500W using Tapatalk
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Yes the bolts will corrode to the lower cover. Best bet is to soak them in penetrating spray, I personally like a little heat and bee's wax.
Could also try drilling them a bit, but make sure to leave enough to get a bolt extractor on there once the lower cover is off.
valleyduramax
233
Ottawa ON Canada
Ya all the bolts are out and the cover will flex up a bit. I'll have to put some more penetrating oil and heat them up some. Last resort is a small hole saw to cut the section around each of the 8 bolts. I have another set of covers anyway if I need to remove this set in pieces. At that point of frustration
