Help: Low throttle smoke
cafryer
May 5, 2011
1,074
Utah
Well guys since i done the 60% and dual pumps my truck smokes bad at low throttle what can i do to tune that out a bit.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Its not hard to fix / improve , but not much advice can be given in a thread really , with out knowing how the truck is currently tuned its impossible to give a direction to go in , and on top of that not every truck takes the same changes , and not all injectors need the same changes .
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
log the condition (rpm, fuel rate, timing) where the smoke is a problem. lower pulsewidth, and bump timing up a little in those areas. That will be a good starting point.
