Having trouble holding railing pressure. My lift pumps pressure seems to be good but I have trouble keeping over 20k on my big tune. Rob says it should hold it fine. I've bottle tested it and checked for leaks and everything is fine. I have no factory filter. Just not sure where to go from here. Its not setting any codes either. I'm having trouble getting over 50 psi of boost and I think this is my problem. I have 120 over Socal injectors, dual stock pumps and the balance rates are good, should I do a return rate test. Any suggestions? I have a fass 95/150 feeding each cp3 and I'm using the stock return line. I was wondering if there's any chance of my return line being to small. Can't see how that would effect rail though.
