LML Low power after deletes and cp3 conversion
diesel53
Sep 16, 2010
907
AZ
So I deleted my 15 Lml entirely, added a fass150, sump, cp3 conversion, up pipes, down pipe, exhaust, 3 inch intercooler tubing, and I tuned with Ppei's ez lynk. Now im just starting to drive the truck but running max effort tuning this truck should move and I noticed it won't even break the tires loose if I try and build boost from a stop.
I would guess this is in the tuning, which I will look into, and I don't think I have a boost leak or exhaust psi leak. But that doesn't sound normal to not be able to burn the tires off the line.
diesel53
Sep 16, 2010
907
AZ
Not sure how ez lynk works but if it's anything like EFI, have you sent logs to Kory?
Yes I will be doing that.
What I think maybe the issue is that when I look through the ecm tunes the only tunes set up for a co3 converted truck are "shift on the fly" and maybe I am actually on the lowest tune considering I didn't get the switch. Not sure if theirs files act like a dsp5 where they default to the lowest/highest tune without a switch in place.
