Low oil pressure
Ruffneckred
May 4, 2014
Just got an Edge Insight CTS2 installed and wow, oil pressure at an idle when temps are up is on 16 psi. I know it is a low pressure, high volume pump but I am concerned. Wondering if my rocker arms and or turbo are getting oil. Louder diesel tick than normal, hope it is just paranoia
justindavis38
Jun 18, 2015
189
29
Hickory, NC
Im just curious not to thread jack or anything but I noticed after I had my headstuds and gaskets done I've lost oil pressure and not real sure how that could happen before I would be running about 60psi at 65 mph right at 2000rpm and now at 2000 rpm after the truck is warmed up its only at 45-50 psi and some times at idle in gets pretty low but not in the red my truck was only gone a month when it started getting warm out but it doesn't get that hot here that my oil should have dropped that much pressure im just curious to if I need to so something or if ita fine. I run T5 rotella 15-40 which I have noticed is getting harder to find also. Any advice? Thanks!
Ruffneckred
May 4, 2014
Thanks for the replies, seems I am not in danger of catastrophic failure just yet, possibly a warning sign. I spend a lot of time idling with the air on. I think I will try the elevated idle mod. I suspect I am putting off the inevitable worn out engine. I wonder how much it would help to try and clean the cooling stack more. I pulled the grill and used our crappy home pressure washer to wash but you can only do so much that way. :(
justindavis38
Jun 18, 2015
189
29
Hickory, NC
Alright ill look to see if im over those values if im not over im very close im I just feel like that little bit more of oil pressure would be healthier for the engine.
justindavis38
Jun 18, 2015
189
29
Hickory, NC
And for your tick try running 2 strovk oil I run tc-w3 from WalMart you can get a gallon for 12$ and I put one ounce per gallon of diesel fuel and then I at my 8 ounces of diesel kleen on top of that and I know if I run a whole tank without it by the time I fill up it starts ticking pretty loud but then if I add the oil back to it halfway through that tank it gets quieter.
