So I did a turbo swap on my 09 lmm and when I was done I flashed my new tune to the truck for the turbo swap. Started it and went for a test drive and it had no power, no smoke, and no codes. So I grabbed my scan tool started to look over live data. Noticed the maf was jumping all over, 0 to 75 to 15 to 170 and this was just at idle. So I figured maf was junk, got a new Delphi in and then went for a drive again. Still no power, no smoke, no codes. So put the scan tool back on and the maf at idle reads 14-17g/s, brake boost it and with the truck floored the best it will do is 37-40g/s. If I do out and floor it and keep it floored for awhile the rpms will get up to a point and then all of a sudden the truck starts to buck, the turbo starts to spool up and make some boost some smoke out the back. So I contacted my tuner he said that in very rare occasions he’s see issues with mafs on lmms and the only way to get rid of the issue is to tune it out pretty much. so he sent me a mafless tune file, flash it in, and it still reads and acts the same way. Talked to the tuner again, he said that it has to be a wiring issue. I ordered up a brand new ecm harness from GM, put it in, and flashed my first tune file back on, maf still reads very low, no power, no codes. I had a new ecm laying around installed that and flashed it to factory GM programming and then flashed it with efilive and maf reading is still the same. So I’m at lost here. Just for shits and giggles I installed the first maf that was jumping around all over to see what it would read and it still jumps all over like it did before. So I have no idea what to do or look for at this point. If someone has any ideas please let me know. I do have videos of scan data if anyone wants to see those. Q
