i have this problem that i can't fix and i need to find out how to fix the P0087 on the LBZ,now i have the 150GPH AirDog on it but when i run the PPE on anything higher then 4 with the TS MP-8 turned up it will trip it if i hit it for a short race and when ever i pull the sled it will trip it roughly 3/4 of the way thru so any ideas on how to fix the problem..i keep the fuel filter changed every 5,000 miles and i have 8-10PSI on the AirDog at full throttle so it's just the rail running low or thats what i think it is...also i have the shim kit but i'm installing a race valve as soon as it gets here.it has almost cost me 2 races and it cost me some pulling distance the other nite at the truck pull,if you listen carefully to my pulling vid you can hear the engine loosing RPM's even while crossing the 290-300FT mark..any help would be greatly appreciated.
