The truck only seems to wanna make 50 psi total boost. started looking at rail press and its only commanding 23,xxx and making 18-21,xxx. Why would it only be commanding 23,000? Is that in the tuning i have or fuel pump related. Thanks
oke:
The commanded being 23k is tuning related, but if you raise it, you still won't be getting more than the 18-21k you're getting right now unless you make some other changes.
what are you talking about? I didnt write any tunes.
What else was changed in the tune? If your truck is commanding 23k and only making 20k, the regulator should be doing everything it can to build up to 23k. The only way it wouldn't is if you had something misadjusted in the regulator current table. If you changed nothing other than desired rail pressure, I don't see how it is possible for your rail pressure to go up. I know I have seen a few LB7 and LLY trucks that threw low rail pressure codes because the truck was commanding 26-27k psi of rail pressure, but were only making 20k. I dropped the commanded to a more reasonable 23-24k, and they stopped throwing the codes but maintained the same actual rail pressure as before.i gained 3k out of my weak pump from it maybe i got a bad regulator
http://www.maximumdonline.com/tvwavs/mcmahon.wavMust be more to the tuning than im seein in the logs i guess.
