LLY: Low boost???
RZRSharp
Mar 7, 2012
54
So I got my banks PDA hooked up today. I put it on the stock setting just to see where I was at as far as readings.
My boost seems awful low to me. I'm new to diesels so I could be wrong.
When I get in the throttle the highest I could get the boost was 15psi.
Just normal acceleration between gears it never gets over 3 psi...
Is this normal or do I really have low boost?
Who needs a computer when you have tapatalk??
RZRSharp
Mar 7, 2012
54
Sorry.
2005 LLY 127,000 miles. Bone stock except the banks six gun.....auto tranny
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
15 does sound low. On stock tuning you should be able to go past 20 psi. Didn't you say you had a smoke issue? Low boost = smoke. Check your connections from the turbo to the intercooler. Power steering lines almost rubbed a hole in my driverside boost tube.
RZRSharp
Mar 7, 2012
54
Thanks. That makes sense about the smoke. I'll look at it tomorrow.
RZRSharp
Mar 7, 2012
54
Would my low boost have anything to do with getting my p1093 code?
Still haven't found the leak btw.
kvert
May 1, 2012
did you figure out your problem yet? I may have some similar issues.
Thanks
Kevin
A_T_Ver
416
1093 is low fuel rail pressure. Change your fuel filter first. But could be a weak FPRV
