1st & 2nd hook 38.1psi, ran awesome....3rd hook 9.6psi . No holes in boots or anywhere we can find. No noises, no nothing. Guess I need to pressure test everything.
You can build a ghetto tester out of pvc pipe caps and test the system for leaks
mine did this same thing. i'm not sure what it was. i just assumed it was something in the tune. i changed tunes to ine that i knew was a good pulling tune as i had used it before
it must be one of those "LLY things" that people claim dont exist/can be tuned out.
ben
I had something odd like this happen today on my LB7 but it was fuel and not boost. They had me test the sled setup and i somehow lost fuel but when they pulled me back and i tried again everything was fine with no fault codes or anything. Made me wish i was logging the run but i got lazy.
Check the vane position. If it isn't constantly changing, you probably cracked the unison ring in the turbo and it is jamming. Very common, especially for people who heat up fast and cool em down fast like sled pullers. Mine is cracked now and hangs once in a while. PITA. I need to pull it some day soon and fix it.
It can. Or at least it has on mine. As it gets worse, it will stick, and stay that way till you agitate the turbo. (hit it with a hammer )
