Loud Clunk When Let Off Accelerator
SmokeShow
6,818
Lawrenceburg, KY
Not sure whats going on but I'm getting a loud metallic clunk when I let off the accelerator pedal. It is most noticeable at lower speeds but I think that's mostly because everything else is quieter when going slower so I can just hear it better then. It does not sound like heavy metal objects banging together. Sounds kind of hollow to me. Sound seems to be coming more from the front of the trans/back of engine area rather than back of trans area. It does not feel bound up and then suddenly lets go creating the bang. It is not dependent on gear, speed or RPM. The trans still shifts the same as it always has. It still seems to be holding the power - can't tell of any TC slip and no CELs thrown. I can't feel the bang in any way - floorboard, seat, pedal, steering wheel. Its just a loud clank.
As soon as I let off of the throttle, it does it.
Any thoughts on what it could be? Cracked flywheel? Something bad in the convertor? it's always sounded kinda like a dual disk clutch at idle. Its an ATS 5-star convertor. Ujoint? Transfer Case?
SmokeShow
6,818
Lawrenceburg, KY
...quit driving with both feet, worked for me to some degree along with a few other changes I did that made the clunk go away on mine about 8 months ago and has not returned......
No two-footed driving here.
Although, I did do a really small (probably less than 1000rpm but for sure less than 1500rpm) 4wd boosted launch about a month ago and it was some time after that this issue started. That was the only two-footed driving I've done recently and I couldn't tell you when the last time was before that.
SmokeShow
6,818
Lawrenceburg, KY
FWIW, I did do a spin-on filter change and fluid top off maybe 1500mi ago. IDT it's the transmission internals causing the issue but just wanted to add all the detail I can think of.
SmokeShow
6,818
Lawrenceburg, KY
Also check the cross member to frame bolts.
That's a possibility and the trans mount too. I'll check those and the engine mounts.
What's a reasonable way to check the engine mounts? Have someone rev it while I watch them? Or hook a hoist to the engine and jack it up to see if the mounts are separated?
5,818
What's the torque spec on the converter bolts? Does it matter that its an ATS 5 Star converter?
they must be red loctited just so ya know.
check the bolts. if those check out, look at the crossmember bolts for the trans and the t-bar crossmember rubber bushing mounts at the frame
