loud chirping in 06 duramax
Spud
Jan 3, 2010
I have an 06 Duramax with 108k. Last week taking off it started making a chirping noise. It is getting worse. It onlly does it between 1300 and 1500. Any advice on how to see if its the turbo or what else I should check? Any help would be appreciated.
2,097
Belt getting old, tensioner getting weak, idler pulley bearings wearing out.
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
Hi welcome. to stare you have anything don to the truck? dose it only make this noise during shifts or when letting off the gas?
Spud
Jan 3, 2010
reply
No truck is OEM, it is quite between shifts and letting off the gas. It only does it between 1300-1500 in any gear its in. Seems like it is louder taking off. the only other problem truck has is minor power steering leak....
T2CH
<<<Me...Not My Wife...
Apr 30, 2008
109
Charlottesville, Va
We all have the power steering leak, kind of the same as the tranny cooler lines. Could be the compressor is kicking on and the belt is worn. Do you have auto climate control? If so, and it is set to auto the compressor will kick on above 42 degrees and continue to run.
If the refrig is low it will not kick on until enough pressure is built up in the system like 1300-1500 rpm
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
You can buy a stethascope sp? from just about any auto parts store. I would start the truck and listen to all the bearings in anything that spins (with bearings, not the balancer and such). You will hear the bearings grind or chirp even at an idle.
I would change the belt anyway, at 108K it's time for a new one.
