LBZ: Lot of play in steering
Jul 24, 2014
51
I've got an '06 Duramax 2500, 6" lift on 35's. I've noticed allot of play, getting progressively worse. What are the main parts to check?
KyleC4
470
Bay Area
Check inner and outer tie rod ends. As well as pitman and idler arm. Also, if it seems like it's getting progressively worse make sure to check the pitman shaft adjuster lock nut on top of the steering box. I've seen a few back off and then the preload is lost.
