LMM: Lost High Idle On DIC After Tuning
RobsDmax
832
Arthur, Ontario
Hi there everyone. on my dads lmm I pulled the tune and made some "adjustments" :spit: and reflashed minus a few items, but when i drove it the other day the elevated or high idle is no longer on the DIC, did i miss something or erase a table in the tune??
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
What year LMM? Did you put in a new tune, or just modified the stock file?
TRUBBS
461
i think in the tune file you can endable/disable the High Idle feature, might wana check there also
Harbin_22
3,858
Southern Indiana
Did you try flashing the stock tune back in it? Does it have the 4 buttons on the dash for the DIC? Sure you are looking through the correct menu?
RobsDmax
832
Arthur, Ontario
Not trying to ask dumb quwsrions, but I have flashed my truck a thousand times with no issues like this
do you use the pedals for the high idle? i just know it had high idle in the DIC when i pulled the stock tune. im gonna ask kory because it was the tune he gave out for free on df
Harbin_22
3,858
Southern Indiana
No I have the buttons on the dash for it. Did you try the pedal sequence to see if it would turn it on? Hold the brake and tap the gas 3 times. Did Kory give a script or a new tune with a different OS?
RobsDmax
832
Arthur, Ontario
havent tried the pedals. the tune kory gave was the same os and was free on the df. but no it was a whole tune no script
RobsDmax
832
Arthur, Ontario
ok heres the tunes.
  • 40 HP LMM TUNE EGR ADJUST.tun
  • DADS FINAL TUNE NO DPF EGR ADJUST.tun
  • DADS STOCK TUNE.tun
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
It's just the freebie I posted on DF for guys to see for learning how to tune. If someone wants to run it that's cool, but it's not like I matched OS for anyone specifically, this is just a basic tune I wrote for folks to check out. The purchased tunes I match everything vs. TIS
