I recently did a conversion from LB7 to LLY (I snapped the LB7 crank) and finally got it all converted over and no boost leaks. Almost everything on the top half of the motor is new except the turbo but VP sensor is new and when logging it I noticed when getting on it the VP drops significantly lower than 55%. Ive got it to 3.1%...in between shifts is when it drops every other time its above 55%..any ideas what would cause this?
