Lol would you like to come up here and have a look for yourself?
All 8 420-440 compression, 8 new glow plugs and one glow plug rail. Last winter the owner was hand priming once in awhile to get it started, I have never had to but it does crank a bit longer to start. 218k on the engine and to my knowledge the injectors and pump haven't been done in at least 130K. Deductive reasoning tells me that good compression, bad balance rates and high mileage equals bad injectors. Are they returning to much fuel, probably, do I need to do a return rate test, um no...
I never said the balance rates could cause his hard starting issue... It's just a quick way to ck the health of the fuel system. Are you going to tell me that if you had bad balance rates on LB7 injectors and a hard starting issue you wouldn't suspect injectors knowing what he has already replaced?
