I have a stock 2001 LB7 with around 330,000 on it, I replaced the injectors about a year ago. For the last couple of months if the truck is parked in any position other than nose down it will run and then die after about 5 seconds, if I pump the primer until it gets hard it fires right back up. If I pump the primer before I crank it I also have no issues. I replace the filter head and hoses and still have had no luck, I also have an aluminum bleeder screw installed.
I believe the next step would be to install a clear hose to the cp3 to see which side it leaks down on? Any other ideas? Thanks.
