Hey all,looking for some input here..saw some coolant on the ground the other day.Was able to get the truck on a lift tonight found coolant down around the oil filter.took the drivers side wheel & inner shield off w/truck running @ temp I could see coolant seeping around an injector..I don't claim to be a mechanic so I don't know the # of the injector(the one on the drivers side closest to the cab)I couldn't see where it could possibly be coming from above that injector...I had a similar issue about 100k miles ago where it looked like the eve cooler was leaking ended up being a pin hole in the head @ one of the injectors,in fact the shop that did the work pulled the injector & pressurized the system & coolant appeared out of a tiny hole barely visible...the mechanic said in 35+years he never saw this...has anyone ever seen this? Or am I missing something above this injector? I really didn't see anything above...I really appreciate any input thanks
