so i just got done doing injectors and a fass 95 install, and the truck is loping most noticeably when coming to a stop. i have watched the desired vs. actual fuel rail pressures and when the truck is warm they are close, and the actual is +/- 2 psi. when i first start the truck the actual is much much higher than the desired. when i did my fass install i did a factory fuel filter delete from fass and installed a gauge there. when the truck is at idle the gauge bounces around like crazy, so i dont know if it is my FPR or inconsistent flow from the fass.
