Loosing coolant at idle
wdino73
735
55
Versailles, Ky
I'm confused so what is new...LOL My ??? is when my truck set and idle for 15mins or longer coolant comes out the overflow, but I just drove 800 miles towing 15000 lbs. and I never lost a drop.. Which leads me to believe it's not a Headgasket. Heads are studed and cometic gaskets. any thoughts???
wdino73
735
55
Versailles, Ky
I changed the cap, I thought about the water pump but I know it's gear driven so I didn't think u could've any trouble with it, is there a way to check it cause it's a job to change it....:)
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
First thing I would do is rule out combustion leaking by. Start it up with the cap off and look for air bubbles would be my first check. Knowing an LB7, there is a good chance an injector cup is leaking. If no air bubbles start out of it then I would say definately check the water pump for a spun impeller which is also a fairly common issue for the DURAMAX.
