Loopey Idle
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
i'm not sure why but almost every tune i load into my truck i end up with a loopey idle even ones that i got from other people. i was wondering if a loopey idle is bad for my truck? i dont mind it aslong as its not doing any long term damage. i have even set all of my below 1800rpm tables back to stock and still get it... is it just my truck?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
does it do it on the stock tune ? i know the tunes i sent dont do it on my truck . i would log it look at cammand pressure , actual pressure , pw , mm3 and then if your getting what your cammanding and there are no differences , check the stock tune log it and compare . when i started tuning fuel pressure tables did this to me when i screwed them up and pw .
on edit might not hurt to check your balance rates too .
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
it doesnt do it on the stock tune but the tunes you sent me do it when i have any load on it like if i have it in gear and am not moving it will do it...
i will try logging everything and see whats going on
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
apperently my truck is very sensitive to pulse width at idle pressure i had to go through all my tunes and change the pw slightly and now back to normal:D
thanks everyone for all your help:hug:
